[phpBB Debug] PHP Warning: in file /homepages/19/d290682188/htdocs/fonction.php on line 14: mysql_connect(): User o3450566 already has more than 'max_user_connections' active connections
Total : 6183224
[phpBB Debug] PHP Warning: in file /homepages/19/d290682188/htdocs/compteur/affiche_compteur.php on line 48: fopen(../stats/2024/06.txt): failed to open stream: No such file or directory
[phpBB Debug] PHP Warning: in file /homepages/19/d290682188/htdocs/compteur/affiche_compteur.php on line 68: fopen(../stats/2024/semaine/24.txt): failed to open stream: No such file or directory
[phpBB Debug] PHP Warning: in file /homepages/19/d290682188/htdocs/compteur/affiche_compteur.php on line 90: fopen(../stats/2024/jour/167.txt): failed to open stream: No such file or directory
[phpBB Debug] PHP Warning: in file /homepages/19/d290682188/htdocs/compteur/nb-visiteurs.php on line 8: fopen(stats/2024/06.txt): failed to open stream: No such file or directory
[phpBB Debug] PHP Warning: in file /homepages/19/d290682188/htdocs/compteur/nb-visiteurs.php on line 28: fopen(stats/2024/semaine/24.txt): failed to open stream: No such file or directory
[phpBB Debug] PHP Warning: in file /homepages/19/d290682188/htdocs/compteur/nb-visiteurs.php on line 37: fopen(stats/2024/semaine/24.txt): failed to open stream: No such file or directory
[phpBB Debug] PHP Warning: in file /homepages/19/d290682188/htdocs/compteur/nb-visiteurs.php on line 54: fopen(stats/2024/jour/167.txt): failed to open stream: No such file or directory
[phpBB Debug] PHP Warning: in file /homepages/19/d290682188/htdocs/compteur/nb-visiteurs.php on line 62: fopen(stats/2024/jour/167.txt): failed to open stream: No such file or directory
Samedi 19/03
Samedi 19/03
Messagepar Mailletou » 18 Mar 2016, 17:43
Je vais rouler demain matin : 25 30 kms départ maxi 9h00. 2 itinéraires à l'esprit : soit la dame blanche avec descente sur Vieilley: départ du parking au bout du chemin de Vieilley
soit quelques forts de Besançon: Bregille, Chaudanne, Planoise .... pour ce deuxième choix je cherche des guides qui connaissent les chemins intéressants et praticables ! Lieu de départ à préciser .
a+
Mailletou
Re: Samedi 19/03
Messagepar nims » 18 Mar 2016, 23:53
Salut mailletou!
Je suis dispo demain matin, et je dois finir tot aussi.
Donc le plus tôt possible me va. Rdv parking au bout de chemin vieilley
8h30 c'est mieux sinon 9h on se redit demain matin je te laisse mon num
0630911097
Bonne nuit !
nims
Re: Samedi 19/03
Messagepar Mailletou » 18 Mar 2016, 23:56
on peut partir plus tot encore si tu veux . en l'absnece de réponse j'allais partir vers 7h30 !!
Mailletou
